Turbo whine
fv43576
x 3
Turbo whine
Unread post by fv43576 »
My turbo is start to whine when on idle, sound is coming from back of engine I am assure is the turbo wear already! if I buy this hybrid from https://www.ebay.co.uk/itm/Turbocharger ... %7Ciid%3A1
How much is improvement over my original turbine? any gain bhp, any reduce in turbo lag and is improve mpg? my car is 306 HDI Estate
I have never fit Hybrid before so I do not know if it is worth to buy?
x 6961
Re: Turbo whine
These would appear to be designed for vehicles that have been remapped - but this is a question that you really need to be asking the supplier as they make them. But if your turbo has failed - you need to ascertain the reason for failure first - which they clearly state, as well as inspecting the compressor and turbine housing before fitting.
fv43576
x 3
Re: Turbo whine
What is the lifetime of turbo if regular maintenance e.g. oil change?
x 6961
Re: Turbo whine
How long is a piece of string? Depends on your driving style and maintenance for one, plus are you one of those who pull up after a journey and switch the engine off straight away without allowing the turbo to spin down? That can cause the turbo to keep spinning without any lubrication and shorten the life of it. Very hard to say, but in all my years of HDi diesel ownership, never had any issues whatsoever with the turbo.
x 1240
Re: Turbo whine
Unread post by Peter.N. »
I wouldn't have thought that a turbo would be turning fast enough to whine at idle - could though be wrong, has been known. :wink:
wurlycorner
x 271
Re: Turbo whine
Unread post by wurlycorner »
Yep, worn turbo's they tend to wine when on boost rather than at idle.
Rather than turbo being knackered, it might just be a leak from the exhaust/emissions system that is dependant on position of an egr/dump valve and therefore only heard when the engine is at idle???
My turbo whistles at the moment when on boost, but that's from a boost leak, not wear in the Turbo.
What car is this on?
Iain
CX DTR T2 Safari (silver)
fv43576
x 3
Re: Turbo whine
Not a great news, at the garage said metal pole turbine is worn because of oil lump clot in oil feed pipe to turbo which is starve of oil that is the reason why is whine at idle. Condition on pole is very bad as he show me.
Now it has been send to recondition and balance for £235. I reckon the previous own may have not change oil filter regular!
Thanks for all your help forum :thumb:
x 1909
Re: Turbo whine
Unread post by Paul-R »
Is this engine a 1.6HDi by any chance?
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Turbo whine
interesting topic for me, one of the neighbour's modern Vauxhalls has quite a loud Turbo whine, I usually hear it as he pulls away; didn't think it could be right, but wasn't sure. Won't bother him to mention, he's not the preventative maintenance type.
Puxa
x 6961
Re: Turbo whine
Paul-R wrote: 05 Jul 2018, 21:40 Is this engine a 1.6HDi by any chance?
If it's the same as a recent request, I think it is a 306 2.0 HDi 90 Paul.....
x 1240
Re: Turbo whine
Never had a turbo go on one of those or the 110.
x 1909
Re: Turbo whine
Exactly my line of thought.
wurlycorner
x 271
Re: Turbo whine
Ok, sorry to hear that news.
As others have said, it's very unusual for the oil feed to block and the turbo to fail on one of these engines.
Iain
