Is this the way that the rear arm bearings start their failure? A very odd time I get a cracking noise on ramp overs or a certain bump in road. Only an odd time in a day, though it went away for a week. I have the bearing kits in stock. I also have remains of a pin which I have drilled and ground down in the hope that ram rod will come out of arm hole. Have also freed of every fastener needed............broke 2 T55 torx bits in the process. Halfords said they had not seen these break before (lifetime warranty). They gave a bright blue spark as they broke. That was a breaker bar and a 5ft ally scaffy tube mind you.
The weather is good, so it is tempting to fit the new kits.
C5 cracking noise from rear
lexi
- x 133
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 5672
Re: C5 cracking noise from rear
May be too little too late Alex but I have convinced myself that regular (excessive) Citroebics helps to keep the trailing arm bearings free.
Could be wishful thinking too
lexi
- x 133
My suspension is up and down a lot Steve. It makes no noises or creaking while doing that. I do wonder if it may be something else making the crack noise? I had the big levers on the arm bushes to check for play, and there is no splaying of the wheels. I can see a grease trace inside the inner faces, so those inside bearings do not look dry. Outer faces are hidden by big washer and bolt head.
I might let it "develop".
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 5672
I was told that mine were shot - a while back now.
I asked two years running that they be checked over thoroughly by the MOT tester and the mechanic who does the awkward bits for me - well, all the bits really.
They could find nothing untoward.
It turned out to be the rear brake pads clattering around due to no anti-rattle springs.
Bearings are and were fine.
I don't know if they have been done in the past, the car looks as though it hasn't had an easy life and is on >225,000 miles now.
lexi
- x 133
Bravo on the big miles Steve. For cars that are basically unloved, they can provide some solid transport and are tough old beasts.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
