Morning all
Quick question if anyone can point me in the right direction for the correct engine oil for my 54 plate 2.0hdi?
Would this be ok? says on the tin recommended for Citroen and Peugeot.
TRIPLE QX Engine Oil (Fully Synthetic (Low Saps C2) Engine Oil - 5W-30 - 5ltr)
https://www.eurocarparts.com/ecp/c/Citr ... 6ec&000398
Cheers
C5 Engine oil 2.0hdi 54 plate?
- x 6945
Re: C5 Engine oil 2.0hdi 54 plate?
Have a look on the Wiki:
https://frenchcarforum.co.uk/wiki/index ... arbox_Oils
You have the DW10BTED4 (With Particle Filter) engine - so 5W40, 10W40 or 5W30 is fine - but you need to use the one for the appropriate climate - so if you have your handbook, it should tell you the PSA specification for your engine, which you can use in the link to find the most appropriate one, but 5W30 is fine.
- x 1489
You don't need one as expensive as that - the C2 Low saps oil is for DPF equipped cars. A cheaper 10W40 semi synthetic will be fine for an 'old school' non-DPF HDi.
- x 6945
Richard - he Does have a DPF though, he has the DW10BTED4 with particle filter.
OnlinePaul-R
- x 1938
Are we sure it's a Mk2 car Marc? Do you have some extra information? A 54 plate could surely be a Mk1 car.
- x 6945
No a MK II - I have Danny's VIN from a previous enquiry, so confirmed. I'll usually ask for a VIN if I don't already have it - it saves asking the same people over and over each time they want info.
- x 1489
danny_c5
Cheers for all the replies folks!
Paul definitely a mark 2, if I mentioned starter motor and your magic hands, I am confident you would remember
while on the subject of oil, would changing the transmission oil make any improvements or worth while?
OnlinePaul-R
- x 1938
Haha. yes - I do remember well. Cheers!
