Hi all,
I changed the gearbox oil yesterday on my BX TD and refilled with EP80 gear oil. All good, or so I thought!
The shift action is particularly crunchy now, nowhere near as smooth as it was before I drained. Do you think the gearoil is too thick?
Anybody got any ideas for curing this nasty shift action?
I've previously used redline MT-90 in a crunchy MR2 with great results...Although it is very expensive! Can I add a thinner synthetic engine oil to the box to help sort the notchy cahnge?
Thanks chaps[:)]
BX crunching gears
Dave Burns
- x 3
ohms69
ScottFromNZ
AndersDK
The BV oil is BV abbreviation in french for manual gearbox - gearoil.
Which means any old type gearbox oil will do - if you can find it - since all sellers seems convinced that new types synthetic oils is wonders from heaven. Simply wo'nt do the job in earlier Citroen boxes as DaveBurns explains.
The BV gearoil should be available from GSF - an early type 75W/80W API GL4 spec transmission oil.
Newer synthetics gearoils have higher spec - more importantly the API GL-5 spec - which won't do in earlier Citroen boxes. May even eat your brass-made syncro's because of the sulphuric additives in newer synthetics.
Donno on the redline MT-90. It should be explicitly spec'ed for boxes with brass made syncro's - else no good.
