Battery help needed
kiwifrog
Battery help needed
Unread post by kiwifrog »
My mk1 Xantia is stranded on the other side of town with a dead battery, daughter borrowed it , long story....Anyway , I going to pick up a new battery on the way over there, but I need to know the physical size of it, the terminal configuration and CCA if posible as parts guys here stare at you blank when you say Citroen Xantia.
Cheers :(
x 1458
Re: Battery help needed
Unread post by xantia_v6 »
According to the Yuasa catalogue, the Xantia battery for the 2.0i is "L2 DIN" casing with standard terminal posts, 55Ah, 550 CCA, 243x175x190mm
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Yes - my battery supplier confirms those sizes however, they quote 590CCA and 63AH. The battery code is 027
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
electronmirror
x 31
Unread post by electronmirror »
The OP has a TD Xantia according to his profile so I'd have thought 590CCA and 63AH was correct for diesel engine and heavy current glow plugs.
The battery spec for the 2.0i Petrol engine wouldn't be so meaty.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
