Hiya. I have tge dreaded antipollution faulty and it showed this code:
P0113 Permanent Fault
Intake air temperature signal short circuit to earth
Anyone knows what this is? And where is the IAT sensor located in my car? Hoping it will be an easy fix. Cheers everyone.
P0113 Fault Code Peugeot 307 1.6v 2007 petrol
- x 1485
Re: P0113 Fault Code Peugeot 307 1.6v 2007 petrol
I moved this to Peugeot as it wasn't a specific diagnostics question.
I can't see a separate temperature sensor in the intake, so it's either with the pressure sensor or part of the throttle housing. Is this a Diagbox fault code, or an OBD reader? Can you read the live data to see if there is any signal from the IAT sensor?
