C3 II HDI 1.6 DMF to SMF
jsp
x 12
Unread post by jsp »
Hi, I have a friends car who needs to be converted to SMF (kit4P).
But, I cant find anywhere a kit4p set?
VIN is: BW531420
Valeo says 835071
x 6956
Re: C3 II HDI 1.6 DMF to SMF
Not available for your car from what I can see in the catalogue. They don’t have kits for all models. The kit you refer to is for a slightly different engine. You have the DV6DTED engine on your vehicle.
jsp
x 12
DV6 dont have all the same crank bolt pattern ?
x 1751
Try ADL-Blueprint. Not sure how well they cover French vehicles.
I have had one of their 4P kits on our RAV4 for several years.
Borg+Beck also offer SMF iirc.
x 6956
jsp wrote: 02 May 2018, 16:25 DV6 dont have all the same crank bolt pattern ?
I think it's not just the bolt pattern, it's also to do with the different engine output / specs / etc., these SMF kits have to be right in order to do the job the DMF does - get it wrong and there's a high risk of damage - that's why they are only gradually adding these to the catalogue - Valeo probably won't have a kit for every model / engine combo - only the more popular makes where there is a higher demand.
x 1751
There also seems to a 'commercial' dimension to the availability of SMF kits. When I was contemplating fitting a kit to our RAV4 (after not one but two OE DMFs had failed), Valeo were an obvious choice, promoting, as they did, a number of kits for various makes of vehicle. Oddly, their catalogue did not contain kits for Toyota diesels, and I had some contact with them about this gap in their SMF range. It was explained that "for commercial reasons", rather than technical, the company could not offer Toyota-applicable kits. My reading of this was that Valeo (or one of their associated companies) were possibly a supplier to Toyota, and this could be jeopardised by their offering a radical alternative to standard installed parts. Just surmise. Locating the ADL-Blueprint kit solved the problem.
x 6956
Absolutely Chris - the commercial angle should not be overlooked.
jsp
x 12
Thanks all just found out this car has a SMF factory so no need to replace the flywheel.
x 6956
Very odd, we have the same engine in our C3 II and that seems to have a DMF.
jsp
x 12
Not all markets have DMF in the C3 II
