Hi
What are the correct size front discs, mines the 2.0 HDI no esp, my search putting in reg number comes up with two types, I thought reg would give correct ones, and I don’t want to start work and they are wrong. I’m thinking it’s the 266 ones but want to find out from anyone who knows 100%
2005 pic 2.0 HDI exclusive model.
2005 xsara Picasso
- x 6950
Re: 2005 xsara Picasso
Well need the VIN - Post or PM
Edit: Ok, got it, give me a minute.
- x 6950
Ok, so these are ventilated and have a diameter of 266 mm, with a thickness of 22 mm. Part number below - but always make sure the dimensions are as I've stated.
1629058880 (DIAM 266 EP 22)
Here's a link to some results for you:
https://www.ebay.co.uk/sch/i.html?_odkw ... acat=57364
Ttwlr
Top man
I like the 1st ones on your list also I like these ones if they fit
https://m.ebay.co.uk/itm/2x-Front-Delph ... Swy79ZdlF3
Thank you so much and for deleting pic
- x 6950
No worries I have it now in case you have any future enquiries.
Ttwlr
Great stuff,
So and discs that are 266 x 22 will fit ok, ? Did u look at link above for lockhead ones ? I
- x 6950
I would stick to the part number I have quoted and search on that - the one in your link does not show that part number and although the dimensions in some areas may be the same it might be different.Ttwlr wrote: 01 May 2018, 15:13 Top man
Thank you so much and for deleting pic![]()
Ttwlr
Will stick with what you said, also while I’m here,
My car did a strange thing this morning started it, got to end of road, (50yards) and when to pull out and it felt like it was only firing on one cylinder, very sluggish, it’s never done it before, I reversed back to drive, turned off looked under the bonnet and all looked ok, I started car again and was fine, done about 40 miles after stoping and starting about 4 times, and cars running Good still, Any idea what it may have been. ?
