56 plate Nissan Primastar
so over the last month or so reverse has been a bit stiff to engage, went our yesterday and I couldnt get it at all, all other gears are fine but thats no good when i need to reverse out of my parking space lol
so any ideas? im assuming as all the rest are ok the linkage is ok, maybe needing greased? not sure where i should be greasing.
any help appreciated
cant get reverse gear
john
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- x 1490
Re: cant get reverse gear
Can you select it with the engine off? If so, then likely the clutch is dragging....
john
no m8 still cant get it
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- x 1490
Don't know details of this van - need to look on top / to the back of the gearbox to see if it is cables or linkages. Cables probably more difficult to lubricate and may need to be replaced.
john
just to update, i bought a set of gear cables and its resolved the issue
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
