Citroen: Heavy loads, best way to park up
x 2005
Unread post by Stickyfinger »
Heavy loads, what is the best way to park up for a couple of days.
Was just wondering...Assume a big load in the car
Is it best to set High, Normal or Low if you are going to leave the car for a couple of days loaded (tyre pressures can be increased) or does it make zip all difference ?
x 1459
Re: Citroen: Heavy loads, best way to park up
Unread post by xantia_v6 »
I would say leave at normal height. At high or low, the weight won't be evenly distributed between right and left (especially on uneven ground).
x 1942
Unread post by Paul-R »
A couple of days? Normally, just leave it as is.
Just how heavy?
x 2005
It really is an "open question" (regarding weight) but as I transport Cast Iron Radiators I often "Max-Load" it :)
Thinking about seals etc.
x 6957
I’ve just lugged back 12 x 25kg bags of stone, 10 paving slabs, turf and bits, - great comfy ride back home with the extra weight, but after the recent front strut replacement pain, didn’t fancy leaving it overnight.
x 1942
If you're really worried then take the suspension to maximum height and then put four axle stands underneath. Make sure they're under suitably tough load bearing areas, lower the car on to them and then leave the wheels, if not dangling, with little weight on them.
x 2005
....with the LDS cap off :)
Michel
Unread post by Michel »
As long as the car isn't over it's max design weight, I'd simply not worry about it at all.
