Hi folks, as per the title, I'm having a nightmare with this motor. The fuel shutoff solenoid blew up (in the wilds of Ardnamurchan, of all places!).
This was sorted back home after removing the armour and screwing in a new single wire solenoid which worked great for 400miles then it too blew! When we took the rubber plunger off and ground down the metal plunger bit and fired it up the engine rattled like crazy so I got towed home again.
Aaargh!
Dispatch 1.9d problems with fuel shutoff
ekjdm14
- x 256
Re: Dispatch 1.9d problems with fuel shutoff
Strange for a stop solenoid to fail, although I did have a 2 wire one die on our ZX.
I have to wonder, given the next breakdown & subsequent rattling, if it is a problem elsewhere. (Hope no filings got in and damaged the pump, what was the reason for grinding the pin? The normal "get me home" is to just remove the innards and use the stop lever to switch off).
What makes you suspect the stop solenoid, have you tested it? I wonder if it's a power supply issue to the pump, since that could also cause a clattery/rough engine if it's one of those with a needle lift sensor and electronically controlled advance.
'96 ZX SX 1.9TD, White, 88k
'98 406sw 1.9TD, Cherry Red, 197k
'98 Ford Fiesta 1.3i 72k
'93 Ford Granada Scorpio 2.9i 135k
Dive Tramp
Yes, the solenoid was completely at fault here. Since it was "butchered" I couldn't take it back for refund/replacement but the van has been performing perfectly well since I fitted a yet another new solenoid.
Incidentally, apparently the loud rattle was due to air in the system which was actually eliminated by pumping the primer over 20 times after fitting the new solenoid (something which the garage chaps didn't know about!).
