ZX Dash bulbs?
x 1507
ZX Dash bulbs?
How many do I need to get to do the dash board and heater control illumination?? Don't want to buy so many the value of the car goes up[:D]
My Wife doesn't like driving it without being able to see the speedo. Oh! Now there's a thought, why bother changing them.....[}:)]
BTW Jon, if you read this, do GSF do coolant temp sensors for Saxos?
AndersDK
Unread post by AndersDK »
N95932 BULB 12V 1,2W 5MM WEDGE DASHBOARD BULB 12V 1.2W CAPLESS (286) 0.35
At this price it won't be a disaster to buy a boxfull - either 12/20/24 pack - whatever quantity they comes in boxed [:)][:D][:p][8D]
x 1507
Yeah, but if I buy 20 and only needed 10, I'll have wasted the £3.50 I'll need to buy the couple of pints I'll need after doing to job to recover! Mind you, I can put them 'in stock' ready for when the Xantia needs doing (probably not that far in the future....)
Guru Meditation
Unread post by Guru Meditation »
Hopefully this might help; I took this picture of my 1993 ZX TD Aura instrument panel as I was changing the bulbs at the same time as fitting a car alarm. My 2p might as well replace them all with new ones, the bulbs are so cheap why only replace the dead ones? Also TEST the instrument panel before you put it back (just wire it in loosely) as one of my NEW bulbs blew the second I switched it on[:(!] It was ok, I just put another in but had I put it all back then tested.....[xx(]
