I am trying to locate from where to buy the window glass surrounds (the upper part of the door where the glass slides up and down and the horizontal trim since the aluminiun inside these rubber(?) trims is starting to disintegrate.
Joseph
Citroen C5 2002-Window surrounds
- x 6957
Re: Citroen C5 2002-Window surrounds
I think I already asked for VIN on your other post - so I'll wait for that to confirm correct part, but in the interim, you haven't said front or rear / left right.....if you can identify the part from the front windows diagram below I can get you the part number to aid in your search- if it's not the front then please be a little more specific.
JosephM
Marc,
VIN is VF7**************[VIN obfuscated, can be read by forum staff]. I am considering all 4 windows parts number 7 and 8. Re previous question, the pollen filter was changed about a month ago. The A/C installed is dual zone.
- x 6957
Part number 7: £55 inc VAT each and still available
9334 A7 - Left
9334 A6 - Right
Part 8 is no longer available - but part numbers below:
9334 C1 - Left
9334 C0 - Right
Rear Windows: Rear Windows Part 8
9334 A9 - Left £30.12 each
9334 A8 - Right
Rear Windows Part 9:
9334 C3 - Left (No Longer Available)
9334 C2 - Right £12.14
9334 A7 - Left
9334 A6 - Right
9334 C1 - Left
9334 C0 - Right
9334 A8 - Right
JosephM
Thank you Mark. Do you know an after market supplier for the unavailable parts?
Joseph
Joseph
- x 6957
There won’t be an aftermarket supplier for these type of parts; your only option is to source them from a breaker’s yard or online parts supplier.
