Dispatch mk 2 radio removal
RPWC
- x 21
Is it just a case of using the pins to remove the set and fit a replacement or, is there special way of sorting it? I want to fit a radio that has socket for mp3 player, will doing this affect the settings for the display, clock unit of measurement for speed etc?
Cheers Rich
- x 6950
Re: Dispatch mk 2 radio removal
The Audio unit is linked to the Multi Function Display and depends on the unit you have Rich. It's generally not a good idea on these, but depends on the unit you have. You may loose steering wheel controls or other functions like Parking assistance if fitted - but would need VIN to check what you have there.
RPWC
- x 21
Will send you it by pm Marc.GiveMeABreak wrote: 07 Apr 2018, 13:36 The Audio unit is linked to the Multi Function Display and depends on the unit you have Rich. It's generally not a good idea on these, but depends on the unit you have. You may loose steering wheel controls or other functions like Parking assistance if fitted - but would need VIN to check what you have there.
Cheers Rich
RPWC
- x 21
Mine doesn't have the parking assist Marc, not fussed about the steering wheel controls either, just as long as it won't change the units back into metric, and the language to French .
Cheers Rich
- x 6950
Drop me the VIN and I’ll see what I can find for you.
RPWC
- x 21
- x 6950
No PM Rich, that’s why I mentioned it. I’ve had several other PMs today from others so I know it is working.
RPWC
- x 21
- x 6950
That’s the ticket, all received. I’ll sort it tomorrow now rich, ok.
RPWC
- x 21
