Citroen Belingo 2003
dayi1000
- New User
The front wipers have stopped working on my belingo , I have checked all wiring and fuses and motor there all fine, so must be the realay on the bsi , does anyone know which relay it is or have a diagram of the bsi so I can desolder and replace the realy ??
- x 6950
Re: Citroen Belingo 2003
It may be the control module within the steering wheel - sometimes referred to as a comms unit. This unit amongst other things controls the lights, wipers and communicates with the BSI.
Sometimes a BSI reset below can help:
- Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
- Ensure all doors are closed and remove key from the ignition.
- Wait for 3 minutes, disconnect the vehicle battery and wait at least 3 minutes.
- Reconnect the vehicle battery, wait a further 3 minutes (do not open doors).
- Switch on the side lights through the driver's window.
- Switch on the ignition (don't start car) and check system's functionality.
- Hold lock button on key down for 10 seconds.
- Remove key open & close door test central locking system.
- Start the engine and complete the system's check.
- Failure to follow this procedure could result in incorrect operation of many BSI related items.
