Waxstat
Eddie Nuff
New User
x 38
Waxstat
Unread post by Eddie Nuff »
My understanding of waxstat's is that the sensor (in gold) reacts to the coolant as it heats up, moving out slowly from its housing until fully out, thereby slowly releasing the cold start mechanism leaving the engine idling at its optimum speed. The gold sensor on this one is permanently out. I've had it in a bucket of boiling water and also the freezer but there's no movement.
Any ideas or is it kapluncked?
moizeau
x 429
Re: Waxstat
Unread post by moizeau »
What car is it on, and is it connected to a cable?
Pete
x 2941
Re: Waxstat
They leak and the wax all gets away, so yes it's likely kaput.
x 6957
Re: Waxstat
I believe that these things have a pin and a rubber sheath inside and then the wax - if the sheath splits the wax can be forced through and then it becomes useless.
Eddie Nuff
New User
x 38
Bugger! Was hoping to get away with this one.
It's for the Xantia, as in my sig, and yes it does have a cable attached.
x 1487
Re: Waxstat
I *might* have one of those in the garage I never got around to fitting.... I'll check later.
Eddie Nuff
New User
x 38
If you come across it at any time Richard I'll take it off your hands even though I've ordered a new one.
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Waxstat
Eddie Nuff wrote: 04 Apr 2018, 17:52 My understanding of waxstat's is that the sensor (in gold) reacts to the coolant as it heats up, moving out slowly from its housing until fully out
the Auto Opener on my Greenhouse roof-light works on the same principle, easier to understand on something as simple as that. Just refitted it for summer (frost can kill it, so in the house for winter)
Puxa
van ordinaire
(Donor 2017)
x 402
Re: Waxstat
If they really are that similar, doesn't bode well for Waxstats fitted through this winter.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Waxstat
:rofl2: cor, there's a thought !! I believe the principle's the same, but hopefully there's something in the detail to avoid the need to take it off for the winter !
Puxa
x 3566
Re: Waxstat
Now there's a marketing opportunity for someone :
"Protect your car's cooling system for winter. Just subsribe to our Waxstat care package for just £(insert random numbers here) and we'll come and remove your thermostat at the first sign of frost each year. Experts agree that if you remove your thermostat during winter then it won't be subjected to the ageing effects of cold." :lol:
