Regeneration on Lexia 3 for x7
dumpvalve
x 5
Unread post by dumpvalve »
Can anyone point me in the right direction regarding regeneration on a 2009 2.2hdi on lexia 3 .. C revision... I either can't be in the correct menu or it seems to say that lexia can't do a regeneration on a x7 model.. I really need to do a regeneration...
MikeT
x 232
Re: Regeneration on Lexia 3 for x7
Unread post by MikeT »
IIRC, mine was found through;
Global Test.
Injection ECU.
Repair (DPF).
Forced Regeneration.
x 6957
I think I answered this on your last post -
viewtopic.php?f=51&t=59845#p571948
You may not be able to force one through with certain error codes still showing relating to the emissions (P0420 in your case). If it won't allow it after having found the location, that will be why.
dumpvalve
x 5
OK many thanks guys
