Berlingo 2 Pollen Filter...
RussellF97
x 10
Unread post by RussellF97 »
My son has just sent me this piece from (probably) Car Mechanics magazine. Because I will probably be getting myself a new-to-me Berlingo Multispace 1.9D (somewhere around 06-09 reg) in the fairly near future, the question arises, how easy are the usual servicing tasks; i.e., changing the oil, air, fuel & pollen filters?
Phil
Indecision is the key to flexibility...
Michel
Re: Berlingo 2 Pollen Filter...
Unread post by Michel »
They're a piece of cake to work on, though you'll only have a pollen filter if you get one with air-con. It's a 5 min job to change as it's in the passenger footwell behind the glovebox. You don't need to remove anything other than a couple of fasteners that let the carpet drop down, and a single phillips screw which holds the pollen filter in it's box. I don't think they ever made a 1.9 with Air Con though. You'd be better off with a 2.0HDi Berlingo of that age. I loved mine, had it for nearly 8 years. It never failed on me.
RussellF97
x 10
Thanks for that Michel. After 30-odd years of fixing cars though, I've just about reached the stage in life where I'd much rather pay someone else to do the servicing and fixing..!
Phil
Lighty
x 34
Unread post by Lighty »
Mk3 Berlingo pollen filter is tricky, but the Mk2 is a piece of cake, as said .
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
