Berlingo Steering Issue
Amison
Unread post by Amison »
Just purchased Citroen Berlingo XTR 90 AU 2012 model.
I noticed a slight vibration when turning left or right which can be felt through the steering and car seat.
Garage can't see any visual fault and are foxed by it.
Steers fine but is worrying.
Any thoughts?
Reason: Reason: Moved Topic to relevant Forum and changed the Title
x 1240
Re: Berlingo Steering Issue
Unread post by Peter.N. »
Could be a wheel out of balance or deformed tyre or failing CV joint. Do you get it if you turn the wheel with the car stationary?
Amison
Thanks Pete.
Wheel balance and alignment done Thursday along with 2 new rear tyres. Front ones OK. I got the garage to check the track rods etc and they were ok. I must say I think it is worse since the garage did the alignment but they checked everything on the ramp and couldn't figure it out. Halfords garage.
Only does it to left and right turn but not always. Only describe it as a mild vibration zip and then gone which is felt through steering wheel and seat. Not constantly repeatable.
Wondering if it's power steering?
Only done 24,00 miles ex mobility car.
Gordon
x 1240
If it was the power steering I would have thought you could replicate it at standstill. Still could be a faulty tyre, check them for bulges in the tread, ply separation can cause this. Try swapping front and rear wheels.
x 6950
I would also get it checked at ATS or somewhere with a proper laser tracking system.
wurlycorner
x 271
Unread post by wurlycorner »
Or CV joints...
Iain
CX DTR T2 Safari (silver)
Amison
Tracking done and OK.
CV joints would have been detected by the guys doing the wheel alignment I would have thought as I had them check the steering and track rods.
Halfords couldn't detect a cause and I would have thought they could have if there was one clearly evident.
Garage seller says it could be as simple as a slipping belt and they would test it out with some talcum powder when I drop it in for MOT.
Gordon
