Our 406 HDi RHZ (220k km) has gear select problems. It locked itself into 3rd gear and with a lot of coaxing would select neutral to enable towing the short distance to the workshop but nothing else. (I can never be angry with a car that breaks down very close to home and keeps the inconvenience to a minimum!)
I have inspected both ends of the cables and find they are good with no slipping, disengagement or anything untoward.
I have removed the cables from the gearbox and tried to select gears with the gearbox levers but it is just jammed up and I can make no sense of it.
I have removed the gearbox (difficult) and partly stripped it to find nothing really wrong, broken or odd. The selector mechanism appears good, the roll pins are in the forks/shafts. There is nothing that appears bent or broken. The only possible problem I can see is some wear on two of the selector forks but this is not severe.
There is a fair amount of black oil residue on the gear cases, more than normal, but the magnet has no chunks or filings on it.
There is no record of the gearbox oil being changed and it was honey coloured when it came out.
Does anyone have any ideas what may be causing the selection problem and what to do from here?
What is the trick to replacing the gearbox housing wrt the selector indent balls?
Farmcit
406 HDi RHZ Gear select problems
- x 1438
Re: 406 HDi RHZ Gear select problems
When the transmission was stuck in 3rd gear, was the gear lever sloppy or firm?
Farmcit
Never sloppy. You could feel resistance but it was NOT like a cable connection had come loose or something.
Also when the cables were removed from the gearbox the levers were very tight & I was unable to select gears by moving the levers directly either.
It felt like it was jammed up inside the gearbox but as I have mentioned I cannot find anything odd inside.
Farmcit
Farmcit
Farmcit
Comments/previous experience anybody?
