Nofps
nelson
Nofps
Unread post by nelson »
Hi
Can anybody tell me what nofps on the dash of a nemo is? Yellow triangle on as well.
Van was running fine. Just had it in the garage changing out the front springs reversed back and left it idling while I closed the door then it stopped with nofps displayed on the dash.
Cheers
x 6945
Re: Nofps
I believe it stands for no 'Firing Prevention System' active. I think it is related to the fuel cut off and the airbags - I've read somewhere that there may be a download to fix this from Citroen - or check the fuel cut off switch first for any issues / faults.
nelson
Re: Nofps
Ok thanks for that. I tried disconnecting the battery and nofps comes on straight away when i try it again.
Do you have any ideas where a fuel cut off could be?
Van is a 1.4hdi.
nelson
Re: Nofps
Solved this problem.
I plugged in the lexia code reader and had no dialogue with the car.
After a lot of looking it turned out to be a broken wire under the fuse box in the engine bay.
Now starts as it should.
x 1464
Re: Nofps
Unread post by xantia_v6 »
Do you have any idea why the wire broke? Was it cut by something, or under strain?
nelson
Re: Nofps
It was corroded and had broken off from the connection that is into the fuse box. Just the one wire that looked corroded all the rest look fine.
