Expert: High Pressure Fuel Pump Removal
perrelet
New User
Unread post by perrelet »
Hello All,
This is my first post here - however a number of existing threads on this forum have proved useful in the past - so thankyou!
I have a 2004 peugoet expert with a rather leaky fuel pump (CP1 bosch common rails). I have a set of replacement seals to do the repair however I am having trouble actually removing the pump. I have managed to remove the 3 main lugs that hold the pump in, however although it is now loose - it will not come all the way out from the sprocket. Am i missing something?
Thankyou for your help in advance :)
x 1484
Re: Expert: High Pressure Fuel Pump Removal
Welome!
I suspect you need to pull the sprocket off the tapered shaft - have you done this?
