Temperature of the engine shows high even if the engine is cold when I drive for a bit of time come back to normal and after couple of minutes goes crazy again is it a sensor or wiring problem that I can fixed myself? Do anyone knows. Where is located
Peugeot 3008 temperature goes high
Marcinsz85
- New User
Dear all I have Peugeot 3008 1.6 2009 exclusive,
- x 6954
Re: Peugeot 3008 temperature goes high
Hi and welcome to the Forum.
Very likely to be a temperature sensor. Post or PM your VIN and I'll see what I can dig up for you.
wurlycorner
- x 271
Or an air lock - that can cause similar problems.
Try bleeding the cooling system in accordance with the correct instructions for the vehicle.
Iain
CX DTR T2 Safari (silver)
Iain
