Its seems that the electric rad fan comes on sometimes before the engine is showing that it is even upto running temp?
I notice also that it is on after i leave the car after normal running ( not hot).
Does anyone else have this issue? is it just a faulty temp sensor of is it something new with these cars?
2013 1.6 hdi 115bhp
partner tepee outdoor. radiator Fan
MikeT
- x 232
Re: partner tepee outdoor. radiator Fan
A couple of points to bear in mind;
1 Fans are engaged if the A/C is running, regardless of engine temperature.
2 The 1.6 is designed to run hot and post-cooling often occurs with mine, even after somewhat sedate driving in this cooler climate.
Not saying you might not have a fault, mind.
dandyman1
thanks for that MikeT. i will take that on board.
