C3 Starting and cutting out
paullap
x 6
Unread post by paullap »
Hi I have this C3 1.4 petrol 2007, It starts and runs great for about 5/10 seconds and then cuts out, I can keep it running by playing with the accelerator pedal, until it gets warm . probably going in to closed loop. then it idles quite nice, I have checked the fuel pressure and that is good.
I have 2 fault codes
P0598 Controlled thermostat signal short to earth or open circuit
P01676 Controlled Alternator control
Where do I start to correct these codes?.
Would any of these cause my problems
I would appreciate any advice,
Paul
x 1437
Re: C3 Starting and cutting out
Unread post by xantia_v6 »
I would start by carefully checking all the fuses, both under-bonnet and inside the car. The fault codes that you list smell to me of a blown fuse.
paullap
x 6
That makes sense to me, Sometimes you just overlook the obvious,
Paul
