How?
I created one draft and went back to edit it and saved it again.
This created two seperate drafts, the second one of which I have now finalised and posted (which then automatically deletes that draft) but the original one remains and I can see no obvious way to delete it.
Delete a Saved Draft?
- x 6957
Re: Delete a Saved Draft?
Mike - drafts are managed through the User Control Panel - go into your User Control Panel, and on the left select 'Manage Drafts'. from there you can put a tick against the one you want to delete and from the bottom choose the action (Delete Marked).
