BX bleed screw
ohms69
BX bleed screw
What size is the brake bleed screw on the bx calipers?[:)]
tomsheppard
ohms69
tomsheppard
oilyspanner
ohms69
AndersDK
It's when you're stuck in problems like this - that fantasy helps you [:)]
Especially if MOT is scheduled next day [8D]
- first thing is to get the bleed nipple out - heat & patience does the trick. A broken bit in caliper means troublesome drilling and oversize bleednipple. Almost any German car uses 10mm metric bleed nipples - available all over.
If you take that route - and the caliper pressure feed pipe is willing to cooperate - then remove this pipe and connect a low pressure air supply.
This will blow out drilling & threading bits. Of course you must wear protective goggles.
This way you dont need removing the caliper - and a broken nipple is no disaster - just a delay.
