Hi, I recently bought a C5X7 with a blown fuze suspension pump motor.
After removing and checking the inside of the motor, which was clean..
I noticed it was a replacement used item.
Is there a re-configuration process in the case of the motor/ pump/ module unit
being swapped from another car.
My pump behaves strangely and seems to pump for too long and for no reason.
The black module on the elec motor gets very hot quite quickly.
It does pump the car up and down on command, but continues to pump and seems to cut out on a timer..
Would Lexia help configure the pump module or is there something else at play here..
Is the reason I wish to buy a Lexia, to clear old errors and maybe fix the pump behaviour that way?
Over and thanks, ur time.
C5X7 suspension pump issue.
- x 5690
Re: C5X7 suspension pump issue.
Please direct replies to this thread to avoid confusion.
