RT4 Amplifier Compatibility
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Moderator: GiveMeABreak
Post Reply
djloui
My Cars: Peugeot 308 GT (2008) with RT4
Post by djloui »
Hello
This is my first post to this forum!
I have a Peugeot 308 GT 2008 with a RT4.
I putted an amplifier that was faulty and I damaged my source! :(
My electrician cannot find any guide to fix this problem and I am very sad about this!
I think my only option is to buy a new/used one...
Do you have any suggestions?
Thank you in advance!
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Re: RT4 Amplifier Compatibility
Post by GiveMeABreak »
Hi and welcome.
Can you please try and provide more details as to what the problem is as it is not clear?
Are you saying the amplifier is damaged or the RT4 is not working?
If the RT4, what is not working? Does it turn on or are some of the functions not working?
djloui
Post by djloui »
The RT4 is working but when I remove the key or when I open the car, a loud scratch sounds from the speakers!
My electrician said that one capacitor is damaged but he doesn't know who specific... :(
C15 Romahome White
CX 20 Polar White
x 5742
Cracking or scratching can be when too much current is being pushed through the speakers - or a surge jumping over a broken or bad wiring connection from the amp.
Remember that the BSI wakes up certain networks when the cart is unlocked or a door opened - and also provides power for a certain time before economy mode kicks in when removing the key from the ignition. So I would check that you speaker wires aren't causing a short somewhere - but may be difficult to trace. If you paid to have it professionally installed - get them to resolve it.
djloui
Post by djloui »
The amplifier is away. the wires are ok. the sound still exits. :( is there any "electrician map" of this Magnetti Marelli so that we can fix this problem??
C15 Romahome White
CX 20 Polar White
x 5742
No, not for the internal unit itself - you would have to contact MM themselves for this - or one of their authorised repair centres. I appreciate you are in Greece, but there are 2 I know of that deal with these repairs - so it will mean sending it off if you suspect the Head unit itself.
Se my post here for details. It might be more cost effective to source another Head Unit - but get a quote anyway - no harm in doing that. I would suggest that if you are going to add an amp - get something compatible. You might want to contact member EDC5 via PM, who has installed a third party amplifier in his C5 X7 and has recently upgraded to RT4 - maybe he can recommend the amp he used....
https://www.frenchcarforum.co.uk/forum/ ... 10&t=54055
djloui
Post by djloui »
Is this one compatible with my screen?
https://www.ebay.co.uk/itm/Autoradio-CD ... 1438.l2649
because if I am gonna buy a RT6 I think that I have to buy the high res screen!
C15 Romahome White
CX 20 Polar White
x 5742
That is not the RT6 (RNEG2) - that one in the link is MyWay (RNEG) - as it has an SD card slot (bottom middle). The MyWay does not need the High Res colour display - but the RT6 (eMyWay or RNEG2) does.
djloui
Post by djloui »
Do you know if RNEG 5 has NAVI?
EDC5
My Cars: Citroen C5 RHR AM6
x 120
Post by EDC5 »
I'm not sure if it's normal but if I start the RT4 up when it is fully asleep I get a 'pop' from the speakers as the RT4's DAC turns on. I don’t get this if i unlock the car and then turn on the ignition as the RT4 has time to turn on before my external amplifier is switched on.
djloui
Post by djloui »
EDC5 wrote: 15 Feb 2018, 10:59 I'm not sure if it's normal but if I start the RT4 up when it is fully asleep I get a 'pop' from the speakers as the RT4's DAC turns on. I don’t get this if i unlock the car and then turn on the ignition as the RT4 has time to turn on before my external amplifier is switched on.
I had the same pop sound when I had the amplifier on!
C15 Romahome White
CX 20 Polar White
x 5742
djloui wrote: 15 Feb 2018, 10:59 Do you know if RNEG 5 has NAVI?
All the RNEG units have navigation.
But I really would consider the cause of the problem first or the same will happen to the new unit - though I’m not sure if you have an actual problem if the unit is functioning correctly apart from the popping noise.
Insulating the wires properly from any of the CAN or live wiring may be a good start.
djloui
Post by djloui »
I bought a RNEG5 and now it's ok
but i don't have SD card for the NAVI.
Any suggestions?
C15 Romahome White
CX 20 Polar White
x 5742
They don't use SD cards, but are updated using the USB port. So if you don't have this, you can't update the system or the maps. This should be one of the important things to check before upgrading. If you don't have the USB, you should be able to get the cable and port fittings from your dealer.
EDC5
x 120
Post by EDC5 »
djloui wrote: 23 Feb 2018, 14:01 I bought a RNEG5 and now it's ok
Any suggestions?
Do you have the Rneg headunit. The one with the SD card reader in the front?
Post Reply
