Peugeot 307CC HDI 136BHP 08 Reg Turbo removal
Digital-man
Unread post by Digital-man »
Hi Guys I have a 307cc Diesel 135BHP 08 Reg. I've noticed the past month a strange whistle sound when I accelerate. It sounds like a police Siren and irritates me. Prior to the sound appearing I had a Turbo Boost pressure ECU error and occasional hesitation.
Everything points to a Turbo or Turbo hose leak but need some advice regarding fixing it. I've checked for any obvious hose leaks in the engine Bay (Intercooler) and all seem fine. I've jacked the car up and tried to gain access to to the Turbo but there is minimum access.
Can anyone advise if they have removed a Turbo from 307cc before and give any advice regarding access and removal?
Thanks in advance
x 1480
Re: Peugeot 307CC HDI 136BHP 08 Reg Turbo removal
I'm pretty sure on this engine you have to remove the subframe to get access.
Digital-man
Hi Thanks for your reply. The shear mention of Subframe removal probably means it isn't a DIY repair at home job and a visit to the local garage is necessary.
When I jacked up the car it looked as though it was possible to gain access by removing DPF and front exhaust heatshield etc. Just wondered if anyone has done the job before and can advise if the Subframe has to be removed or not.
Digital-man
if anyone has removed a Turbo form a 307cc without removing the Subframe can you let me know? Thanks
