Heaters blowing hot constantly on c2 furio
Webo83
Unread post by Webo83 »
Hi all my 05 c2 furio is blowing hot air constant even on cold I've done a therm change I've checked the back of the control panel and the one wire that is there seems to be working fine it changes all speeds and settings fine just blows a constant un changing heat even on cool any ideas much appreciated
x 5690
Re: Heaters blowing hot constantly on c2 furio
Stuck air direction flaps.
Happened a time or two on mine then resets itself after a couple of restarts but there is a more serious failure mode where the flaps become distorted by the heat and stick, stripping the gears on the motors that move them.
Webo83
How do I go about checking that myglaren and thanks for the reply
Webo83
Or what part would I need I know these things can be fiddley little buggers if you have to start stripping the dash I cut my knuckles 3 times just checking the control panel lol
x 5690
Webo83 wrote: 07 Feb 2018, 22:36 How do I go about checking that myglaren and thanks for the reply
On a C2 I couldn't say but it will no doubt be fiddly at the very least.
x 6950
So likely to be the air mixing flaps - post up your VIN and we'll have a look.
Webo83
OK thanks I'll get the vin numbers up
Webo83
Here's the vin thanks
VFJMHFXB
97286795
Webo83
Thanks everyone it's SOLVED I felt up under the passenger footwell to where the cable moves the pulley to move the flap and the cable had come free that end when I move the pulley arm by hand it works blows cold when I push it up and hot when I pull it down so thanks everyone
x 6950
That's one off the list - just your ABS to sort now, well done. :-D
Webo83
Thanks only with your help else I would be stuffed paying out the nose for these answers via a garage
