2001 Citroen dispatch 2 litre hdi.
Its just recently played up.
Temp gauge-- sometimes nothing happens with ignition on , on the other hand when ignition switched on, temp goes to max then off, then thats it '
I have changed the thermo and green thermo temp switch.
Now ignition on- temp goes up and down twice then nothing?
Whats the fix please?
Van runs sweet and always a nice cool water temp ( When gauge worked)
dispatch HDI 2.litre Coolant guage not working now!
ekjdm14
- x 261
Re: dispatch HDI 2.litre Coolant guage not working now!
Sounds to me like it could be an instrument failure, but not knowing a great deal about the more modern stuff I could be a way off & it may be a wiring issue. Have you confirmed that the sensor is the one that operates the gauge, and that the new one is indeed working and making good contact with it's connector?
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
ghiaman
Hi.
thanks for the reply.
I will check the new sensor
