HDi fuel shut-off?
milleplod
x 15
HDi fuel shut-off?
Unread post by milleplod »
My '09 2.0HDi has an annoying little issue! :evil: It drives very nicely....when on the throttle. If I'm on the over-run, for example when going downhill, there's an annoying 'stuttering' that feels as if the fuel is being cut off, almost like a misfire...its particularly bad if I touch the throttle very lightly.....its fine if I press the accelerator harder, which I tend not to when going downhill!
Is there any sort of valve/sensor somewhere that might be misbehaving? :?
Pete
Nocto Diuque Venamur.
x 1955
Re: HDi fuel shut-off?
Unread post by Paul-R »
The HDi engine cuts the fuel off on the over-run anyway. If you have a fuel consumption readout then you can see this as a reading of 999.9mpg - the closest it can get to no fuel being used.
You need to get the car on a Lexia - but you already knew that I'm sure.
milleplod
x 15
Yes, I'll have to have a run up to Savoy Garage to see Malcolm re Lexia. I wondered if anyone had ever noticed anything similar - its almost as if the fuel's not being shut off on the over-run.
Pete
