key fob and clocks resseting resolved
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
after sorting my heater blower not working on my 07 plate 807 I thought I would have a go at getting the 4 button key fob to work,
most key fob problems seem to be dead fob battery or pairing issues, mine was much easier,
The HS SH fuse found by your right knee side scuttle fuse box had been moved from user to park, prehaps to save battery power overnight. I moved it to user and voiila.
Now my keyfob works as it should and the constant resseting of the display time and date has also been resolved.
hope readers of this post might want to check the HS SH fuse to see if its in the right position and making good contact.
On to the next problem of the cruise control not working, and if the car has been tweaked from 120hp to 136hp.
wotwot
(Donor 2021)
x 4
Re: key fob and clocks resseting resolved
sorry RESETTING
