Xantia - Are Hydraulic seals needed when replacing strut tops
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I about to replace the strut tops. As mine are NFP I have to replace the 3.5mm hydraulic pipework. Citroen dealer in Israel does not have in stock 3.5mm pipe seals ( Citroen part number 96085785 'Hydraulic pipe lining' 3.5mm). Are there 3.5mm pipe seals on the pipes that hooked to the strut top ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1487
Re: Xantia - Are Hydraulic seals needed when replacing strut tops
Unread post by xantia_v6 »
It depends on what you are fitting. Can you give the part numbers of the strut tops and pipes that you are fitting? or if second hand, exactly which model and year of car did they come from?
lancia58
(Donor 2022)
x 8
Hi
As my car's strut tops are NFP ( 5271F5, 5271F6 ) I have to change them to 5271E1 and 5271E4. Since the threading of the new struts are different from the originals I have also to replace the hydraulic pipes that are hooked to the struts. Citroen part number for the new pipes are 5270 96 and 5270 EC.
