Replace struts (rear door) C5 2005 // estate
wbgenetic
Unread post by wbgenetic »
Hello guys,
I've been holding off with this change for quite some time now - but not having a proper rear door (5th door) for the trunk (meaning: it closes automatically :D) literally means that the trunk is like an old closet ...
I was not able to find a guide and would like to ask you - if available to supply one as to how to replace (at least the small struts in the rear).
(I do have both bought and ready).
Thanks!
x 1490
Re: Replace struts (rear door) C5 2005 // estate
wbgenetic
yeah, i've seen those but not much is seen there in terms of the actual disassembly of the head-lining for example ... isn't there a manual of some kind (I know the guy in the video mentions that the Haynes manual mentions visiting a dealer... nevertheless)...
x 2938
The headlining isn't too much of a problem, you peel it down from the middle after removing the plastic trims on either side, it's held in place with double sided adhesive pads and folds back enough to do the job.
Like all modern cars the trims are held in place by plastic pegs so just need a bit of careful levering to get them off.
The most difficult bit I found is getting the circlips off the inner end of the struts because you're working upside down and can't get a clear view, I chucked the pliers aside and prised them off with a screwdriver in the end, they buckled a bit but were easy enough to re-shape and pop back on to the new struts.
You'll need some muscle :-D
wbgenetic
Now... Some muscle I have ... lots of muscle not sure - sort of subjective here :)
Anyways I read in a few places that after removing those circlips at the end - there is the option to not re-install them again afterwards (for the rear end). Which would make future endeavours of this kind a much nicer experience...
x 2938
That's right, they don't seem to do much because the weight of the door holds them in place, I suppose that if you pushed the door up too far they might pop out of place.
