torx bit size???
latheaxe
torx bit size???
Unread post by latheaxe »
Anybody know what size of torx bit is for removing the seats out of 2007 c4 Grande Picasso????.. Ta! :-D :-D
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: torx bit size???
no, but in general, I've found they're a T40 on the (rather older) stuff that I've spannered and that a 10mm ratchet head spanner can be a real boon on 'em (the Torx Bits) where there's not room for a more 'conventional' approach.
Note that I've found there's considerable value in getting underneath it, to see if any of the bolts poke through beneath the vehicle; clean them off if so, I've mullah'd Seat Bolts before now trying to get filthy threads to turn, its not a fun situation to be in.
Puxa
x 1489
My guess would be T30 - I can check later if you really need to know? They don't stick under the car floor. Note that if the seat is stuck (which they seem to prone to, have already had to do the pass seat on ours once - pen in the runners - and it is stuck again!) then you need to dismantle it in place to get it out. Which is not a whole heap of fun....
x 1489
My learned friend is right - T40 they are :)
