Another 307 question (wheel bearing)
doctle
x 225
Unread post by doctle »
I need to replace a rear wheel bearing on the 307 its pressed into the disc. Can it be hammered out and a new one pulled in with a large nut and bolt or do I need a press? Thanks
Oh buggle
moizeau
x 429
Re: Another 307 question (wheel bearing)
Unread post by moizeau »
https://www.frenchcarforum.co.uk/forum/ ... NG#p543663
previously mentioned, I just searched 307 rear wheel bearing, good luck
Pete
doctle
x 225
moizeau wrote: 18 Jan 2018, 17:26 https://www.frenchcarforum.co.uk/forum/ ... NG#p543663
That was my post! Unfortunately the cheapo bearing wasn't a success I'd like to change it myself rather than having to get a cab to the guy with the press wait until it's done and get a cab home again.
Oh buggle
x 1484
You can certainly do them with a threaded puller - I've got a set like this which I've done a few fronts with. You need a meaty centre piece, as they take a lot of pulling. At least if it's been out relatively recently the circlip won't be too hard, and it shouldn't be stuck in. Still haven't done mine, but it is getting to the unbearable stage, and quite likely an MOT fail in a few weeks, so I'll be digging the kit out again soon!
doctle
x 225
I have some 3/4 drive sockets and a massive eye bolt from god knows where I might give it a go. The centre isn't under much pressure as the stub axle runs through it. Thats a nice looking kit useful when you dont have a press
Oh buggle
