406 Cluster a LED or Bulb and noise on clutch.
fv43576
x 3
Unread post by fv43576 »
My wife Peugeot 406 saloon HDI 90bhp Rapier 2003, the cluster on the left side is dark, I think the bulb has fused but on the Youtube it shows how to remove the cluster it shows have LED. I am confused is my wife have LED or Bulb??? if it is LED then I am in a big trouble will to buy the whole cluster because the LED is non-replacement.
Another problem is the clutch start to making noise like screeching metal is rub when release the clutch the car is fine drive normally on all gears no slip & go up the hill fine. I want to eliminate the problem do this have a solid flywheel? I know the sound of DMF when fail, could be the clutch release bearing worn? I know my old 306 2.0HDI 90 did have solid flywheel which is same engine on 406 can anyone help me?
thanks
x 1480
Re: 406 Cluster a LED or Bulb and noise on clutch.
Very unlikely a 2003 car has an LED cluster; I expect it's a normal bulb.
Screeching when the clutch is pressed is most likely the release bearing; a 2003 90 BHP will be a sold flywheel, pretty sure.
fv43576
x 3
RichardW thanks :thumb:
