EFI conversion
Raul
EFI conversion
Hi
Anyone here who has done it or considering it in the future?
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
- x 8391
Raul
Re: EFI conversion
On citroen gs/a . There are some old youtube videos of the cars that have been converted but a link to the step by step build thread would be excellent.
- x 8391
Re: EFI conversion
Gosh! Converting a GS/A to EFI sounds to me like a big project indeed...
These days I guess Megasquirt would be the way to go...
Michel
Re: EFI conversion
CitroJim wrote: 09 Jan 2018, 09:44 Gosh! Converting a GS/A to EFI sounds to me like a big project indeed...
Looked into this for the DRK with a megasquirt .Not too bad or expensive to do both fully electronic ignition and fuel injection. The theory for the GS would be the same, though siting the injectors and supply to them would be interesting. Plenty of other flat-fours with injection though.
Could get rid of the awful dizzy too..
Raul
Re: EFI conversion
I found a thread about vw beetle:
https://www.aircooledvwsa.co.za/viewtop ... =4&t=27984
Quote from there:
"I'm in the process of making up a kit to cost effectively convert any type 1 air cooled vw engine to EFI without having to cut or physically modify anything.
Here's the basic idea...
Use the original vw intake manifold, bolt on a throttle body with internal injector, use the original 6mm fuel line and a Mexican beetle fuel pump..."
Basically using the same idea shouldnt it be pretty easy? I am a complete newbie on petrol cars and efi-s so maybe I am strongly underestimating the complexity of that kind of project.
Quote from there:
- x 1459
Re: EFI conversion
I did quite a bit of research on EFI conversions a few years ago, but am not familiar with the GSA configuration.
A few points (many of which I am sure you already know):
- A multipoint system will usually give slightly better starting and running performance than a single point.
- You can get injector bosses to weld into the manifold tubes, the injectors should be pointing at the back of the inlet valves.
- You will need to mount a suitable throttle body (perhaps with integral TPS and idle control valve).
- Any manifold preheating system should be removed.
- You need a high pressure fuel pump and recirculating fuel system. The pump should be mounted near the tank and no higher than the bottom of the tank. There must be a suitable fuel filter after the pump, and no filter before it.
- You should fit an inertia cut-off safety switch.
- Any rubber hoses downstream of the pump (including return hoses) need to be replaced with material rated for EFI pressure.
- You need to mount a timing wheel and pickup sensor on the crankshaft, or possibly camshaft, this must be mechanically sturdy.
- You will need to mount an additional engine temperature sensor (not sure where it would go on this engine).
- You would need to fit a manifold pressure sensor (MAP), unless integrated into the ECU.
- You will need to mount a 4 cylinder coil block (or 2 double ended coils).
- Most people fit an oxygen sensor to aid tuning and provide closed loop fuelling operation.
- x 1751
Re: EFI conversion
Am really no expert on this, but I would guess there could be issues with emissions testing.
If OE fitment (eg carburettor), then you could be exempt from later/latest requirements.
If significantly modified, then you might have to meet more recent emissions figures, which could be difficult.
The only way I'd do this was if there were a "bolt-on" EFI option from later vehicles which used the same engine. I'm thinking eg Rover V8 here: originally twin carbs, later an EFI manifold and kit.
Contactless electronic ignition should be easy. Might be worth doing that first, as it will contribute a lot to starting, combustion and low-speed running.
Michel
Re: EFI conversion
http://www.megasquirtuk.co.uk/
You'll need the hardware, as listed by XantiaV6, but the actual ECU and programming/mapping isn't that hard to do with modern kits. You'd be able to run the Ford EDIS ignition system on a GSA 4 pot too, which takes away a lot of the hassle. You'd need to use 1 injector per cylinder on a GS. Getting hold of secondhand manifolds and modifying them is the way to to this.
There's been plenty on the TV on various classic car shows about the advantages (many) and disadvantages (very few) of fitting EFI to classic cars - lower emissions, better economy, better performance and driveability etc..
- x 1459
Re: EFI conversion
I converted my 1972 E-type to EFI and UK MOT testers never batted an eyelid, nor did they ever actually perform an emissions test.
- x 1751
Re: EFI conversion
It was probably so well done that they thought it was OE!xantia_v6 wrote: 09 Jan 2018, 22:44 I converted my 1972 E-type to EFI and UK MOT testers never batted an eyelid, nor did they ever actually perform an emissions test.
How many testers bother to check factory spec for a car, unless there's a glaring issue, or it's a first matriculation/re-registration inspection? Even then...
Raul
Re: EFI conversion
I found a link to the multi point injection conversion.
http://eddinsmoto.com/id131.htm
sonoramicommando
- x 5
Re: EFI conversion
Raul wrote: 10 Jan 2018, 18:29 I found a link to the multi point injection conversion.
Looks like this guy went out of his way to do things the hard way - but that's fine as he has the means to do all the fabrication work himself, which means it didn't cost a lot of money and time.
The question is, do you have all the resources and the knowledge he has at his disposal...
Like others mentioned, most people go for megasquirt as a universal ready made solution, so that's your best bet - I think there are a few Fiat twin cam folks who have done that (having said that, Fiat 124s are pretty popular and numerous in the US).
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
wurlycorner
- x 271
Re: EFI conversion
white exec wrote: 09 Jan 2018, 21:26 Am really no expert on this, but I would guess there could be issues with emissions testing.
The emissions requirements are done purely on model build year, here (unless you've swapped the engine to one from a different model year and declared it/the MOT tester realises it).
There are plenty of carb classics out there that have had EFI mods done (single point being the most common/simplest). Has no effect on emissions test requirements.
Iain
CX DTR T2 Safari (silver)
Iain
Mandrake
- x 695
Re: EFI conversion
Why just convert to fuel injection, why not turbo charge as well!
https://www.youtube.com/user/emknapss/videos
120hp he claims from the dyno run, eg double the original factory horsepower.
Makes a bit of a difference to the acceleration:
Yes, it is a mad Kiwi behind those videos and I don't condone his driving...
Great sounding engine with a noisy exhaust fitted I have to say.
Wonder what happened to that car as these videos are over 10 years old now...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
