Power for Aux Gauges
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Has anyone ever fitted an Aux Water Temp sensor, such as this one?
https://www.ebay.co.uk/itm/2-52mm-Unive ... SwB-1Y7FUK
Daughter's 1.1 TU Petrol C3 (2005) clearly has Electrical Gremlins (I'm thinking a dry joint or similar in the ECU) which is resulting in a false 'Overheating' reading, especially on long runs
Further to viewtopic.php?f=3&t=59057&hilit=sender I've replaced the Sensor and established to my satisfaction that it is a false reading.
I know there's a spare 'Port' available on the 'stat housing (the AC port is blanked off). but where would I take power from?
Modern Rubbish!
Puxa
x 6961
Re: Power for Aux Gauges
See my post here on this thread for a similar situation and the previous posts that may or may not be relevant:
viewtopic.php?f=3&t=58407&start=15#p561394
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Thanks Marc :)
Puxa
