ECU mounting
Eddie78
ECU mounting
Unread post by Eddie78 »
I have a Berlingo 2.0 HDI mark 1 and the ECU is just flopping around in the engine bay it is fastened to a steel back plate but the plate is not fastened to anything, currently it is jammed between the battery and the black relay box,
Has anybody got any info on how this should be mounted? just I dont like the idea of it getting bounced about
Michel
Re: ECU mounting
Unread post by Michel »
There should be a couple of bolts above the top of the suspension strut on the inner wind kind of below the edge of the wing, and one similar on the bulkhead. The backplate bolts to these, and as you see, the ECU bolts to the backplate. The bolts are well hidden!
Eddie78
Re: ECU mounting
so it mounts above the strut? lying flat?
Michel
Re: ECU mounting
Yes, there should be two cut outs in the opposite side of the blanking plate to the side the ECU plugs go. They "hook" onto the bolts which stick out the side of the inner wing, and there should be another on the side of the backing plate that attaches to the bulkhead
Eddie78
Re: ECU mounting
spot on thank you, makes sense now, the n/s strut has been changed (breakers marker pen on it) and like most jobs that have been done on the van they where half cocked
Michel
Re: ECU mounting
I'll see if I can find an underbonnet pic of mine when I get home in the morning to give you a more accurate idea - I should have one as I swapped out the ECU for a remapped one, and took pics of taking it apart.
Eddie78
Re: ECU mounting
That would be great if you could
Eddie78
Re: ECU mounting
had look today and all sorted thank you
