c5 cruise control retro fit
kevino
x 4
Unread post by kevino »
Hi Guys, I've bought a c5 2.0 HDI VTR saloon. I love it but the only thing is I would really like cruise control? Is it an easy fit or are there a lot of money pits along the way?
I've been told it can be as simple as plugging in the control and turning it on? let me know your thoughts before i go charging in and make an arse of it.
I want to go peacefully in my sleep just like my granddad, not screaming like his passengers
x 6948
Re: c5 cruise control retro fit
You will need the secondary Brake switch, (a clutch switch if not already fitted if manual gearbox), the Cruise Control / Speed Limiter control module to be attached to the Steering Wheel Control Module and it will need to be activated in the BSI by Diagbox. So not quite as simple as plug and go.
You haven't stated what year the C5 is MK I, II or III - better still a VIN would help.
kevino
x 4
oops sorry to mention it is a mark one
x 1056
Unread post by wheeler »
I did do a how to with pics & screenshots on here but cant for the life of me find it now ??
x 3298
I have fitted a cruise control stalk to my C5 Mk1. You will have to have access to a Lexia (either your own, or there are forum members who can help) to let the car 'know' she has the stalk fitted. As has been said, you will also need to check the brake pedal to see what switch it has. There are two possible wiring configurations, and with the earlier configuration there are two switch options.
Wiring 1. There will be two pairs of wires, one pair will end in a white plug (which will be fitted to the white brake light switch), while the other will end in a red plug. This may (or may not) be connected to a red switch. This red switch is a push to break type, and will disengage the cruise control when the pedal is pressed. I believe that (should you require one) this switch can still be purchase.
Wiring 2. There will be four wires ending in a single plug. If you have this option you will have a dual switch (brake light/cruise control disconnect). Nothing further needs to be done re brakes.
Once you have determined the brake pedal switch situation you will need to buy the cruise control stalk (and, if like me, you are poor at accurate sawing) the lower steering wheel cowling (I got mine from a scrap yard for £15 for both parts). There are (if my memory is correct) a couple of Philips screws holding the lower cowling in place. Undo these, and drop the lower cowling away. You will see a cover over the relevant hole. Remove this cover, and then fit the cruise control stalk. Before fitting the replacement cowling it would be a good idea to activate and test the stalk, just in case.
Connect up the Lexia and go into the menu relating to the driver switch module. Somewhere in there will be mention of the cruise control stalk (and this will be set to "Absent"). Change this to "Present", and save the setting. Now you will need to test it. I cannot remember exactly how to do this, but you will be going into a driver switch menu, and then the cruise control. Press each of the CC buttons (and rotate the on/off switch) and check that the Lexia is 'seeing' each state. Assuming it all works you can fit the new cowling.
On the Mk1 C5 the cruise control will only work on 4th and 5th gear, and at speeds of 40MPH and higher.
wurlycorner
x 271
Unread post by wurlycorner »
It's very simple if you pick up the 2 bits you need and have access to a LEXIA.
There are pics in my C5 profile thread (linked in my signature)
You might not need the second brake switch - later mk 1's apparently had them fitted anyway, so check your car first to be sure.
Iain
CX DTR T2 Safari (silver)
x 1476
Unread post by xantia_v6 »
wheeler wrote: 28 Dec 2017, 19:24 I did do a how to with pics & screenshots on here but cant for the life of me find it now ??
I have now restored the missing instructions, linked from viewtopic.php?f=3&t=45175
kevino
x 4
Many thanks for all of the replies. I will need to gain access to the lexia from somewhere? And other bits including the stalk. Am I right in saying that the brake switch is in the passenger footwell? Where does the stalk plug in to? Cheers kev.
kevino
x 4
Just looked at the guide to fitting the cruise control, it answers questions asked in my last post. Cheers kev.
kevino
x 4
Just bought the stalk. Now need someone with the lexia near me in Blackpool to turn it on. Any one offering? Please.
x 1944
Unread post by Paul-R »
Take a look at the list here
viewtopic.php?f=19&t=56452
Then PM someone who is close to you. Be aware that some members on the list might not be active any more as people seldom let the forum know when they leave the hobby.
Before contacting anyone have you confirmed that you have the suitable brake switch(es)? Early Mk1 C5 were missing the suitable switch although the wiring will be present. Later cars either had the two switches or a combined single switch.
x 1056
Don't think there is any reason that you wouldn't be able to configure the CC even if the parts were not fitted, once the parts were fitted it should just work if it was pre configured.
x 1944
Yes but if it is the early type without the extra brake switch then not having it would delay the final outcome. I was just checking, that's all.
kevino
x 4
I need to chuck my head under the glovebox and take a proper look. Ill let you know the outcome about the switch if its dual or needing a secondary.
kevino
x 4
Just thought it is a c5 2.0 hdi on an 04 plate, and a vtr. Dont know if that makes anything clearer?
