Citroen C5 - Windscreen Washer Sprays don't work below 0 degrees C
shine_moon
Unread post by shine_moon »
Hi everyone.
New poster here. I have a 2013 C5 wagon that I love.
Only problem is - I can't drive the car in temperatures below 0 degrees C because the windscreen washer sprays don't work. Using the washer stalk activates the wipers but no spray. When a truck in front of me sprays up road debris, I have no way to clean the windscreen. I've had to pull over a couple of times on the highway to manually clean the windscreen.
I've tried various anti-freeze wiper fluids with no luck.
The wipers and spray work flawlessly from 1 degrees C upwards.
The car is currently with me in Poland where I'm working on a project. Any tips on solving this without having to drive the car back to the UK for a service?
Many thanks!
x 5676
Re: Citroen C5 - Windscreen Washer Sprays don't work below 0 degrees C
The recommendations here are Bluecol and Halfords ready mix - I will admit to not having tried either.
As a temporary solution try adding half a litre of either meths or isopropanol. Should stop it freezing but will take time to work through the system.
x 6947
That will simply be a matter of the brand of screenwash you use!
You need to buy a brand that protects to minus temperatures. I would of suggested the Halfords 5 lt extra protection stuff as I’ve been using that for over 10 years without it ever freezing.
If possible get some that you don’t dilute that provides protection down to -5 to -10 or better and get that circulated through the washer system. Problem solved.
x 1746
Probably not a Halfords in Poland.
Advice is good, though - choose a brand of screenwash that provides below 0degC protection.
Some cars are fitted with heated screenwash jets - check yours out, and whether they are working.
Doesn't stop the fluid in reservoir and pipework from freezing, though.
The jets are the most vulnerable, as they are in the icy airflow while driving.
x 5676
Probably best to ask the Poles what they use as they will be used to low temperatures.
x 6947
white exec wrote: 13 Dec 2017, 19:01 Probably not a Halfords in Poland.
I realised he was in Poland Chris - but just forgot to qualify that! :wink:
There are no heated washer jets on the C5s though. :x
x 1746
Shame they're not heated.
x 6947
I've actually only ever had an issue with the washers freezing once - and it was in a bitterly cold winter where even the Halfords stuff had issues - but as a rule, this stuff is pretty good - you use it neat and as long as you like the smell of blackberries, it does a great job of degreasing the screen too. It's never really let me down and that's saying something about Halfords - although it's guaranteed to be made by a proper company.
x 2004
Unread post by Stickyfinger »
Mix in Russian Vodka, I bet it is cheaper than Screen Wash. Really however, I used to use isopropanol 50-50% with standard Screen wash as you can get that in 25ltr barrels dirt cheap.
milleplod
x 15
Unread post by milleplod »
I use this stuff - https://www.screwfix.com/p/no-nonsense- ... GwodDe4P5w
Diluted 50/50, we had -6 here the other night and no sign of freezing. :-D Although I appreciate that Poland probably doesn't have Screwfix either! :oops:
Pete
Nocto Diuque Venamur.
x 5676
milleplod wrote: 13 Dec 2017, 20:53 I use this stuff - https://www.screwfix.com/p/no-nonsense- ... GwodDe4P5w
Pete
Just bought 5x5L of that for £19.95 - got a bulk discount :)
milleplod
x 15
myglaren wrote: 14 Dec 2017, 17:52
Pete
I do the same, as soon as they do it at the special price, best stuff I've ever used! :)
Pete
Mandrake
x 695
Unread post by Mandrake »
I have undiluted -10 degree rated screen wash in my Peugeot Ion and in the last week when we had temperatures down to -4 to -7 degrees both front and rear jets stopped working completely until the temperature was above about -2 again. Very annoying when the windows were getting filthy but I couldn't clean them...
It occurred to me that even though the screenwash itself might freeze below -10, when there is a good overnight frost you could still get precipitation forming on the outside of the spray nozzle that is pure water and thus freezes below zero and then blocks the tip of the nozzle... (hence the need for heated nozzles)
Anyone else see this problem ? I was meaning to get a hair dryer outside to warm the nozzles to see if this was indeed the case but didn't get around to it before the low temperatures abated.
As its an EV there would be no engine bay heat to help warm the spray nozzles.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 6947
I also think the concentration and quality of the washer fluid makes a difference - however some might consider fitting one of these:
And a demo compared to a car with a heated windscreen (apparently)
crapday69
(Donor 2017)
x 59
Unread post by crapday69 »
GiveMeABreak wrote: 15 Dec 2017, 15:37 I also think the concentration and quality of the washer fluid makes a difference - however some might consider fitting one of these:
http://www.ebay.co.uk/itm/HEATSHOT-HEAT ... SwcRNZqBK5
£49 on ebay with a make an offer, so might get it for around the £45 mark. Might get one after I buy a new battery.
