wiper washer failure
froggy
- (Donor 2026)
- x 4
Hi, my S2 Xantias' wiper wash has stopped working ! there is fluid in the bottle, not frozen. I am wondering could the motor be kaput ! it would be a first for me. or maybe the fuse? if it were the fuse, would anyone know which number fuse ? as I do not have a manual
any help would be great. cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Pug_XUD_KeenAmateur
- (Donor 2018)
- x 228
Re: wiper washer failure
Could well be that the delivery lines have frozen this time of year, have a listen see if the motor's making a noise, or try it again on a warmer day.
Puxa
froggy
- (Donor 2026)
- x 4
I have blown through the pipe into the bottle, and Iam making bubbles in the tank !
Terry
My project C5 had this problem, the pump had simply stuck from lack of use and a good clout set it going again but I replaced it with a new one from Ebay to be sure.
There was then the problem of split pipes behind the under wing shielding and the water dripping onto the road instead of getting to the jets.
Easily fixed but a bit of a pain to get at.
Stewart(oily)
- x 35
Hi Gibbo, I have a C5 to fix the inoperative washers on, did you access the pump via the wheelarch ?
Stewart(oily) wrote: 09 Dec 2017, 11:24 Hi Gibbo, I have a C5 to fix the inoperative washers on, did you access the pump via the wheelarch ?
I did but it may be different according to model, mine's an 06 2.0 litre hdi 138, the pump on this is under the RH front wing right at the front, a bit awkward to get at because the electric power steering stuff is in the way........but do-able. The piping trails over the top of the wheel arch protector and feeds through to the jets right at the back.
Stewart(oily)
- x 35
Thank you for that, I just need the snow to go away and I can explore under there.
Timmo
- x 168
When you change the pump, make sure you have a bucket underneath to catch what pours out the reservoir,
I picked up a pump from the local yard for a couple of quid, came from a 306 if memory serves,
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
