I will very soon be entering the 21st century by collecting a 57 plate C5 2.0 16v HDI VTR 6 speed estate to replace my Xantia!
It needs a replacement dual mass flywheel, I'll do the clutch at the same time and I'm told that its a good idea to replace the starter motor as a precaution.
The cambelt history is unknown, although the aux belt does look in pretty good nick, I'll replace both anyway.
Is there enough space for the gearbox to drop to the floor or does it need to slide across? I have an engine/gearbox support beam and am familiar with replacing clutches on the 1.9 Xantia and 2.1 XM.
I assume the hydraulic system will need to be depressurised to remove the gearbox, is there any gotchas to bear in mind here?
Any other hints and tips?
I will sort out a for sale advert for my Xantia over the weekend.
My new C5 - looking for advice on replacing the flywheel and cambelt
red_dwarfers
- x 58
Kev
'19 C4 Cactus 130 Flair
- x 1493
Re: My new C5 - looking for advice on replacing the flywheel and cambelt
I've done a clutch on one of these, it's not a great deal of fun... viewtopic.php?t=33060 Ref the PAS pipe, the official Citroen procedure is just to remove the bolt from the subframe, but we couldn't get the box out even then. Jim's done a cambelt on one of these, pretty sure; not too hard as I recall - the injection pump is driven off the end of the cam, so the belt is crank, cam, water pump only.
wurlycorner
- x 271
Garage I had my clutch done at, said they drop the front subframe out, because that's the easiest way to get suitable access for the rest of the job.
Iain
CX DTR T2 Safari (silver)
Iain
flying clutchman
- x 3
The gearbox is a very tight fit. I've done a few of these and haven't enjoyed it. Loosening the subframe so you can give yourself another inch or two leeway helps. The front bit can be taken off quite easily, but there's not much room to get the box out.
hamster99
In my experience of changing the turbo on my C5, dropping the sub-frame makes a huge difference to access the underside and back of the engine/gearbox.
However, you may want to take a look at the Citroen site as when I needed to get my clutch/DMF replaced they were doing deals on it. I priced up the various parts and the all-in price from Citroen I think was about £150 more. I decided for the hassle involved I would get them to do it.
They had an offer on too when I had my cambelt changed, although that was one I could more easily have done myself but was really busy workwise so didn't have the time.
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
red_dwarfers
- x 58
Thanks for the advice.
Kev
- x 1996
Kev, have you looked at a Solid Flywheel conversion? I would have thought with your driving style you would not notice any extra harshness of clutch engagement.
red_dwarfers
- x 58
I did have a quick look in to it, I can't find an off the shelf solid flywheel kit for the post 2006 16v diesel. To be honest, I'm of the thinking that if it was designed with one then I should probably replace it with one. Hopefully my driving style will mean it will last a long time!
Which engine does your C5 have Alasdair?
Kev
- x 1996
2ltr Auto 136bhp so the same engine I think, tows a large If-Williams 4 wheel trailer with a Xantia on it OK
The Mk2 C5 I had was a 1.6HDI, I did not get on with needing to rev a diesel to pull away on a hill with a loaded boot
so was glad it fell down a big hole
- x 1746
On Toyota, I repeatedly found that hill-starts with DMF were not good, and required lots more revs than normal. Trouble is, on a steep incline, torque is 'stored up' in the DMF springs (which can compress by up to 45deg of rotation), and the way this 'lets go' is pretty much out of the control of the driver, who has direct control of the clutch, but not the long springs. When I converted to an SMF, from Blueprint, normal clutch control became available.
I think the choice of whether to convert is a very individual one, depending on how well or otherwise the DMF had behaved.
wurlycorner
- x 271
Not had any driving style problems (e.g hill start delayed torque) whatsoever with the dmf on mine. Wouldn't even know it had one, from that perspective.
When it comes to slow speed reversing a loaded 4 axle car trailer up hill, I do wonder if the dmf heats up more quickly than a solid would (contributing to clutch burn) but that's my only question / concern. Other than that, it's all win!
Iain
Iain
