807 brake pedal going down
Humph7
Unread post by Humph7 »
The pedal seems to be going slowly to the floor. There are no leaks to be seen anywhere. Is it the master cylinder? it has done 250,000 kms
x 2943
Re: 807 brake pedal going down
Two possible reasons, if the car has ABS/ESP and the pedal only creeps down with the engine running then it could be air in the ABS, otherwise it's likely to be the master cylinder seals and at that mileage a new master cylinder would be needed although you might get away with fitting a new seal kit.
Humph7
The abs shows a fault on the screen - could that be linked? I will order a new kit otherwise.
Humph7
Could that indicate a faulty abs pump? There is a problem and the garage suggested a new steering angle sensor and pump.
x 2943
Go to this thread there's a lot about it and if you scroll down I posted a video of the procedure for secondary bleeding.
viewtopic.php?f=3&t=58737&p=553888&hili ... o#p553942
Humph7
The pedal only creeps down with the engine running. Should I be able to hear the abs pump working like in the video?
x 2943
Humph7 wrote: 03 Dec 2017, 12:01 The pedal only creeps down with the engine running. Should I be able to hear the abs pump working like in the video?
No, that's the automatic bleeding working, you will only hear that when you're using the diagnostic kit to bleed the abs. pump.
As shown in the video you keep a little foot pressure on the pedal and the system does the rest.
Humph7
Is this good enough?
https://www.ebay.co.uk/itm/TOPDON-OBDCA ... 0290.m3507
Would air in the system throw a fault message?
x 2943
Sorry that's not something that I'm competent to advise on.
Sloppysod
x 367
Unread post by Sloppysod »
Humph7 wrote: 03 Dec 2017, 13:00 Is this good enough?
Have a read of the manual, it looks like it is a scanning / fault finding tool only.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
