807 gearbox filler?
Humph7
807 gearbox filler?
Where is the gear oil filler on a 807 2005 2.2hdi?
jgra1
- (Donor 2021)
- x 36
Re: 807 gearbox filler?
Humph, others will know more about this, but if that gearbox is anything like most other manual PSA boxes of the period, get some access, pop the white/black cap off the top of the breather (top of gearbox), grab a tube and a funnel, and throw the oil in that hole
- slowly
Humph7
I have seen that hole, but it would be easy to overfill.
Michel
Take the level plug out of the end plate on the side while you fill it through the top. When it starts to dribble out the level plug hole, stop putting oil in.
Humph7
Will have a look tomorrow. Cheers
Humph7
Could not find any side plug whatsoever. Some oil drained out from the driveshaft hole. I hope there is enough oil left to continue
jgra1
- (Donor 2021)
- x 36
hmm, I have a feeling some gearboxes dont have the level plugs Humph.
Normally I just drain and stick the required amount back in, either 1.8 or 2.2L (I think, depending on box)
I don't understand why oil is escaping the driveshaft though, that implies one of the driveshaft seal's are worn.. has it been leaking before?
John
John
