2.0i oil top up amount
faddy
- x 4
Dipstick at Min, how much to fill to Max? (2008 C5 2.0i)
- x 6955
Re: 2.0i oil top up amount
I wouldn’t add by quantity, just add a little until it is between min and max levels. Check level on flat ground and when engine has been off for at least 15 minutes.
- x 1929
When's the next service due? If it's fairly soon then, providing it doesn't drop below min, I would leave it alone.
As an afterthought, how many miles since the last oil change? Has it always been near the min mark?
wurlycorner
- x 271
As others have said, check by dipstick to make sure you get the level right. As a guide, it will be somewhere between 500ml - 1litre though.
Iain
CX DTR T2 Safari (silver)
Iain
- x 1751
- x 6955
Be aware too that the computer engine oil level indicator that comes on for a few seconds (when switching on the ignition), will only be accurate after a period of 30 minutes after topping up!
