What is making this sound? C5 mk. I
Willemies
Unread post by Willemies »
lexi
x 133
Re: What is making this sound? C5 mk. I
Unread post by lexi »
When I had that sound, it was Alternator clutch bearing. Having a number of spare belts from different cars, I found one that fitted with the alternator bypassed. Silence. It may also be one of the other belt tensioners. Experiment till you determine, rather than strip and replace parts willy nilly.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Willemies
lexi wrote: 22 Nov 2017, 11:38 When I had that sound, it was Alternator clutch bearing. Having a number of spare belts from different cars, I found one that fitted with the alternator bypassed. Silence. It may also be one of the other belt tensioners. Experiment till you determine, rather than strip and replace parts willy nilly.
Alright, thanks for your comment, I'll check that out.
x 5674
Same here, alternator clutch replaced for around £35.
